Anyone any experience of fixing this?: The red dashboard light with the picture of a battery is on permanently when the car is switched OFF.
Everything was normal until I went for my first spring-drive yesterday (was a glorious day here on the west of Scotland).
Started on the button, car was superb to drive as normal. Did about 15 miles.
Parked in the garage and switched off.
As I was getting out of car I realized there was a red light on the dash (top of the clock). The battery warning light.
I switched ignition back on, the light goes out - all other lights look normal.
Started car, the battery light goes out. All lights as expected.
Switched ignition off, battery light comes back on.
I assumed maybe the battery is on it's way out and this is warning me (but I've never seen before when the battery is low).
I didn't have time to investigate so I disconnected battery out of caution.
Today I went to investigate. Multi-meter says battery has 12.48v so it's ok, could be higher, by certainly not low.
Reconnected the battery and the battery warning light came back on immediately.
Started car, light goes out. It started quickly as if battery is in good order.
Stopped car, light back on.
I found these two threads elsewhere so it looks like it's either some loom damage or a diode in the alternator:
http://www.911uk.com/viewtopic.php?p=1520243
https://rennlist.com/forums/993-forum/425714-alternator-light-on.html
I had the recall list checked when I bought the car it had no outstanding recalls.
Anyone here had to fix this?, if so what was the solution?
