Battery voltage display
Watty37
Does anyone know how to permanently get the battery voltage to display in the rhs dial?
I have the turbo pressure, water temperature etc as one of the 4 possibilities, I can select the battery voltage as one of the 4 options but I cannot get it to remain there. I have the 14-way electric seats and the OPC thought that it was related to a seat memory setting, but that doesn’t seem to work either.
Thanks, Michael
I think you need the memory package to save any displays you want in the rhs dial. I think the button you need is on the door .
Consult the handbook is probably best practice with step by step instructions.
Nike Pike Boxster technical assistant might be able to help in more depth he is very technically minded with electronic gadgets.
Varies by model, and sometimes by age of model. For example, in my 2013 981 it was impossible to get battery voltage in the RHS display -it wasn't on the list of alternatives available. It appeared sometime later in the model's life and is available as an option to select on my 2016 981. You don't say what model and year yours is (presumably a 718 as you mention turbo pressure), which would help folks to respond accurately.
Brian,
My 981 Boxster S is an early 2013 model and permanently displays the voltage in the right hand display together with water and oil temperature and oil pressure. As the car still has the original battery, I found it reassuring! I think I managed to add it to the display when I bought the car but can't remember how I did it!
Perhaps it is related to other options such as the PCM version?
Steve
You can have up to 4 values displayed. The manual will tell you. I think it’s under ‘multi function display’
Dan
