Battery Tray Corrosion (Series 2)
- Thread starter 944 man
andy watson
Moderator
Not quite such a bargain though!
£4.50 postage!!! + the VAT makes a total of £11.32
Why do these companies rip people off with postage?
http://www.ebay.co.uk/itm/Car-Boat-Battery-Acid-Absorbing-Mat-20cm-x-30cm-Great-for-acid-leaks-E128-/380476092036?pt=UK_Car_Accessories_Car_Care_Cleaning&hash=item5896246e84
ORIGINAL: 944 man
Youve missed the point somewhat Colin. It obviously needs to be cut out, but simply saying cut it out and 'replace it' does not actually provide an answer.
It isnt 100mm square of .8mm thick mild steel, its a convoluted shape.
I'm sorry I was talking generally. The only effective way to get rid of rust is to cut it out.
You could contact one of the breakers and have them cut one from a scrap car for you or you could make a new one from a sheet 1.5 mm steel.
I wont get back into the garage until Wed night, but I'll have a look at mine and see how hard it would be to make a copy of the battery tray.If make one I'll send it to you.
I may have a serviceable one in a car up here Simon but it is not an easy job to get it out or put the new one in. If there is metal missing underneath, it is best to cut a hole out the bottom when you are reaplcing that as it is easier to get into the bottom of the panel.
Alasdair
944 man
ORIGINAL: colin944
ORIGINAL: 944 man
I would appreciate that Colin, thank you.
It looks like a terrible job Al, even if you have a car / rear 1/4 with a perfect tray...
I had presumed that people attempt to cut out only what is corrosed on their own car, but I cant see how you would get to do a proper job.
Simon
