Awkward little sod !
Frenchy
Changed the small radiator to solid pipe hose today on the turbo, what an awkard
sod, anyway's weep should be sorted now, but still have an intermittent cut out, changed the coil, King lead, DME,runs fine but cuts out and stops now and again, pushing my buttons??
Does the car still have the immobiliser fitted? they can cause intermittent issues as they get old.
Steve, removed recently along with a ton of other added wiring, not started today, changed the DME for another yesterday started on the button but still not convinced, time will tell.
Could be the crank postion sensor Jim. Pop the top off the DME relay and make sure both internal replays pull in. If only on pulls the position sensor is toast.
2 new Bosch jobbies recently Bob, changed the DME relay for another spare, starting on the button, need to some confidence miles in it.
Doing cars in the park on the 6th in the 330i touring, retro show at Westmorland Showground the week after in the 944, then the following week same venue ESPCC in the BM again.
Bought me a Mini Cooper S R53 supercharged pocket rocket [;)]
944 now behaving !
Going to the Nurbring Oldtimer in August if interested, Hotel, no camping ?
The usual suspects tagging along.
