Are You Bored ?
- Thread starter 944Scott
Hairyarse
ORIGINAL: 944Scott
Can you guess how many pegs are being used here ?
Just a few? [
Sandspider
Ex Skyline
944Scott
ORIGINAL: simdel1
I need to do the same with mine. It was starting to come slightly loose, so I peeled it back and used spray glue to re-stick it. That was a bad idea because it's worse than it was before now!
Yep thats the problem I had, hence the gorilla glue and pegs, yes its messy but it has worked a treat.
If anyone can guess right I will send you the cheapo pegs [
For reference, spray glue wasn't strong enough and either was EvoStik contact adhesive. No More Nails was the last stuff I used, and that's held for the last 18 months (which is 12 months more than the other two.) It's not pretty ast all, but all the ugliness hides behind the panel so you can't see it.
Clothespegs in the picture? I'll guess 200.
944Scott
ORIGINAL: zcacogp
I've done exactly the same with my roof panel. Three times. And decided that clothespegs didn't exert enough force, so used metal springy document clips.
Did these mark the edges (which type did you use?) I still have the roof panel to do as im changing it from dark blue to the linen colour.
j4mou, i'd need a lot of super glue [:-]
Two types, like these:
No, they didn't permanently mark the edge; they left an indentation once removed, but the vinyl was springy enough for the indentation to disappear over a couple of days.
ETA: The first type (above) is Porsche Workshop Tool CLIP001 and the second (with the folding handles) is Porsche Workshop Tool CLIP002. Bob, Porsche updated all workshop tools made of wood sometime around 1968 ...
