944 man
...or does anyone know whether theyll pass aluminium bolt on additional sections as seen in Appendix 2 drawing 9 (the side to side braces, not the door bars). Im considering one piece running under the dashboard and another bracing the base of the rear roll hoop. I realise that aluminium cages were outlawed a long long time ago, but I believe that these will be acceptable because theyre over and above the minimum specification thats required. Both proposed bars will be perfectly straight and they are intended to work in compression only.
