Am I being thick or.....
- Thread starter Keyzy74
One is for starting and the other for running I think
bertelli_1
Keyzy74
Drew
vitesse
There are normally little tags on the cables identifying the sensors-however you can look at Clarkes Garage to get more info.
I parted both these on my e-bay 924S suffering from fickle starting patterns,tried to get the sensors out but couldn't,so just sprayed with WD40 & replaced these Bosch plugs back together.
Bingo,got the tacho flicker & car started.
However,same problems again a few days later-repeated the above adding petroleum jelly-started immediately but repeated the problems soon after.
This week,broke the Bosch plugs again,& slightly twisted the male pins to give a better "grip" in the female part-this seems to have sorted the problem for the time being.
