A little advice please, I am in the process of removing the alternator from my 1977 911sc, I have managed to remove the whole fan assembly from the car and have managed also to prize the inner fan located by the key way also from the unit.
The next fase is to remove the alternator from the outer fan unit, the unit has around 6 long allan bolts presumably holding the alternator together but are these also holding this unit to the outer fan as it appears to be solid and has no movement what so ever, could this be due to the alternator being corroded in the mounting or am I missing some form of mounting bolts, any help would be appreciated.
Cheers Baz
Cheers Baz
