Hi guys, I had the car in for a full alignment today after replacing all the suspension, etc.
The guys have done a great job but can't get the front camber anywhere near where it should be. This issue is that the flange on the shock body which presses against the eccentric seems too thick to allow the full rotation of the eccentric.
I did repaint the shocks before fitting them so will get the dremel out and a wire brush first and consider replacing the eccentric bolts if they aren't stupid money.
Has anyone come across anything similar before? Strutss are Koni M030 height adjustable.
Thanks.
Thanks.
