Fellas, I have had my car in bits after some minor bodywork and paint, decided to rebuild the brakes, new
cross drilled vented discs all round, along with pads and wear sensors and a full calliper rebuild, slider plates now out (basta rd job) .
The brake calliper are now off for blasting and powder coating, better job said Carl the powder coater if we take the seals out then we can acid dip them but will knacker the seals, phoned OPC (Kendal) you can only get the seals with new Pistons basically £200+ a corner......ouch !
Rang Bigg Red £60 odd for the full seal kit with club discount and they have chucked in some new Brembo bleed nipple covers Gratis !
Hopefully all back together with with new oil and coolant by the end of the month [
Big recommendation for Bigg Red for service if you are doing brakes.
