wolfie308 said:
Hi Matt,
Here's a photo from a customer of mine..... I think the wheels are 18" Veloce 3.6's. Thought you'd like to see especially as it features other mods including bridge spoiler, Cup mirrors and of course clear rear lenses [
Personally, I prefer period correct wheels and one of my favourite upgrades are 17" genuine Cup 1's which I'm lucky to have on my new S.2. Complete with KW v.3's, for me, this is a great setup. Would it not be better to get suspension sorted before choosing wheels? Anything over 16" and you'll have to fit 968 castor mounts before you start.
Thanks Wolfie..
To Berliner
Hi, It cracks me up when you get a "warning" that somebody may hound you on fitting wheels! Superb..
So you've now got a 944 3.0S2 on the way, and your thinking of changing the wheels ?
The ride comfort will be worst, the car slower than it could be etc...But if your looking for "a cosmetic Look" go for it.
The 18" BBS 2 piece split rims were found on the Boxster's and also the 911's, although the rear were 9" and 10"
9" Will go on, but 10" will be tight or foul on the body.
The front Rim widths are 7.5, you could even source and use all (4) 7.5" but this would most probably mean buying 2
sets, so if you find a rear 9" put 265/35/18 on it and 225/40/18 fronts.
The veloce wheels can be a problem when the lacquer on the Rim chips from stones and wear and tear, because
water will then creep inside, lift the lacquer off further an the aluminium will corrode and leave white milky deposits..
From memory the Fake bolts cannot be removed (I think they are Glued in?) and there'a high chance without getting these out
the Wheels cannot be re-machined polished (Diamond cut) or even if they can the costs can be approx ÂŁ150+ per wheel.
Originally the 18"Split rims also had a Diamond cut outer rim,which also does the same although a lot of these
have been painted and lacquered Silver the same as the centre.
If you find out what the Offsets numbers are of any prospective Wheels and also your current ones i can work out
exactly how much more or less than stick inwards and outwards...
R
