I've noticed the the AC in my 987.2 produces a slight hiss in the cabin (sounds like it's coming through the face vents) when the blower motor is on quite low and the temperature is set to maximum cold. When I turn the blower up the hiss diminishes. The AC seems to cool the cabin quite well. Is a hiss a characteristic of the Porsche system or does it indicate that something is starting to fail somewhere(?).
AC Hissing
- Thread starter michael.williams1
Have to say my 987.2 2.9 2009/ 85K mile Boxster does not to this, but we do not use the A/C much tbh.
Personally I don’t recognise that phenomenon on my 987.3 CS Michael, but then I just leave my cabin temperature set to about 20 degC and let the climate control sort it out. Maybe the sound of the blower motor is drowning-out the hiss? It’s very noisy when on full blast!
If you can hear the hiss when outside the car there could be a leak in the system.
Jeff
Jeff
Thanks Jeff. No I can't hear any hiss when I'm outside the car so I don't think it's a leak, it definitely puts out ice cold air and there's condensation water dripping under the car after a run, so everything seems to be working ... Google AI tells me "a slight hissing sound can be normal as the expansion valve regulates the refrigerant flow". Maybe that's what I can hear(?). Anyhow, the AC will likely get a good test on my road trip through Spain and France in a few weeks, so I'll see how it does!Personally I don’t recognise that phenomenon on my 987.3 CS Michael, but then I just leave my cabin temperature set to about 20 degC and let the climate control sort it out. Maybe the sound of the blower motor is drowning-out the hiss? It’s very noisy when on full blast!
Jeff
Ian’s suggestion certainly is a possibility. You should be able to access the fan by removing the cabin filter [I’ve done this on a friend’s 981, but it should be similar for the 987]. If it is the fan you’ll hear it better, as well as being able to make sure that it’s spinning freely.
Enjoy your Euro trip, and I hope that the Cayman behaves itself.
Jeff
Jeff
Different on 987. Glove box has to be removed to drop the fan down into the footwell.Ian’s suggestion certainly is a possibility. You should be able to access the fan by removing the cabin filter [I’ve done this on a friend’s 981, but it should be similar for the 987]. If it is the fan you’ll hear it better, as well as being able to make sure that it’s spinning freely.
Jeff
Mine did exactly the same.
Then packed in.
Quick Google search told me I was likely low on gas.
After investigation, found both condensers were leaking.
Had them both replaced.
Sorted.
If it's any help, Groupon are doing a regas at ATS for £47.
They do a leak test first.
If they find your system is leaking, they refund you your £47.
Just had this done on my old Mondeo.
Hope this helps.
Then packed in.
Sorted.
Hope this helps.
If the air-con is blowing ice cold, it's not a leak. Re-gassing equipment carries out a limited leak test before gassing. However this is not definitive.
When my AC stopped working, I suspected a condenser leak. A large chain (not ATS) were offering free AC checks. I was assured that the machine would not re-gas if the test failed. Test passed, AC re-gassed and was fine for a few days. They re-gassed again FOC, same result. I then took the car to a local garage which does AC repairs. They used a fluorescent dye in the fluid which allowed them to detect the leak, condenser as suspected. They were horrified that the chain did not add dye when re-gassing.
Sometimes it's difficult to know what to do for the best. When mine was serviced at a reputable indie, they told me the gas was low. Checked it for leaks. Said it was fine and topped it up with 500g of refrigerant. Holds 850g apparently. £90.If the air-con is blowing ice cold, it's not a leak. Re-gassing equipment carries out a limited leak test before gassing. However this is not definitive.
9 months later the hissing started. Month after that, the AC packed up.
The indie I use now found it straight away. Both condensers rotten.
Repaired. Still going strong a year later.
Thanks all, that's very helpful, certainly gives me a few places to start looking. It will probably have to wait until after the holidays as I'm a bit reluctant to start pulling the car apart a week before we go. Hopefully the AC will see us through the holiday and I can investigate further when I'm not going to be so reliant on it as the weather cools.
The AC seems to be doing ok for the most part, but in Spain we’ve had some very high ambient temperatures of nearly 40 degrees C and it couldn’t keep up with that. Is that normal for a Porsche AC system or should it still be pumping out ice cold air at 40C?
The aircon system can only reduce the temperature of incoming air by a certain amount Michael, so I would imagine that it’s ability to maintain really low cabin temperatures will be compromised with the high ambient temperatures you’re experiencing in Spain.
Hope the trip’s going well with no Cayman issues.
Jeff
Jeff
Yes, it’s going really well with no issues and very good fuel economy. Mostly excellent roads in Spain and France which aren’t congested with traffic, although it was quite busy crossing the Pyrenees though Col Du Portalet. Some great back roads off the toll roads in Southern France to enjoy the PDK in sport mode manual.The aircon system can only reduce the temperature of incoming air by a certain amount Michael, so I would imagine that it’s ability to maintain really low cabin temperatures will be compromised with the high ambient temperatures you’re experiencing in Spain.
Jeff
Update: After our European road trip I took the car to Porsche Bournemouth for a check over. They noticed the AC was a bit noisy and found a leaking condenser (front left), so that is going to be replaced. The car isn’t fitted with the Zunsport grills so I’m thinking about fitting those to keep out the autumn leaves etc! However, I’ve read that Porsche don’t recommend as they reduce airflow …Sometimes it's difficult to know what to do for the best. When mine was serviced at a reputable indie, they told me the gas was low. Checked it for leaks. Said it was fine and topped it up with 500g of refrigerant. Holds 850g apparently. £90.
Repaired. Still going strong a year later.![]()
I have used Zunsport grilles for about 15 years. No problems with cooling at all, even in 40+C at alpine altitudes. No problems with leaking condensers either. I just remove them if going to OPC for service but even OPCs seem to be not bothered according to some. If you are planning to be competitive in the Le Mans 24h then the cooling might possibly be an issue but maybe not the highest priority even then. I did notice once in a heavy snowstorm that snow tended to collect on the grilles but didn’t impact the water temp and easily wiped off.
Was it leaking from "rotting" - leaf build up or from impact damage (likely higher up) - grills will help with the leaves ( but so does a long hoover hose or an air line ) but would be less effective at stopping small stones will have some effect - but some will get through..Update: After our European road trip I took the car to Porsche Bournemouth for a check over. They noticed the AC was a bit noisy and found a leaking condenser (front left), so that is going to be replaced. The car isn’t fitted with the Zunsport grills so I’m thinking about fitting those to keep out the autumn leaves etc! However, I’ve read that Porsche don’t recommend as they reduce airflow …
Good point ... looking at the video from Porsche Bournemouth it could be the victim of higher up impact damage as there seems to be a leak coming down from near the top. I did check both sides for leaf debris when I bought the car 4 months ago and found they were very clean with no suspicion of any corrosion. However, I've done over 3K miles since then ... Perhaps, if I'd had grills fitted, it wouldn't have happened.Was it leaking from "rotting" - leaf build up or from impact damage (likely higher up) - grills will help with the leaves ( but so does a long hoover hose or an air line ) but would be less effective at stopping small stones will have some effect - but some will get through..
I think it a little “luck of the draw”.
Mine has got the original condensers in place. 15 years old. No grills. So far. So good. Of course tomorrow I may get a stone hit
Personally i am not a fan of the zunsport grills - I don’t think they look very “integrated” on 987.2 but that’s a personal thing.
I think Porsche don’t have a problem with zunsport - they don’t endorse them (or resell them) but I think the “airflow “ fall back commentary is there to cover more amateur setups that could impact the airflow so they play it safe.
I was told by local OPC service manager that they didn’t “care” but if i came in with a potential warranty claim for overheating then the first thing they would say is “take the grills off and see if the problem is still there”
