abs loom sections wanted.
eddieedmo
Finally got car up on ramp to sort ABS , all the loom sections from wheel to main ABS loom are shot , all earths badly corroded and snapped off from the barrel connectors where they are moulded in - no wonder ABS has been faulty.
So I need 2 loom sections for front and 2 for rear.They are the double ended barrel connecton sections which the sensors plug into from the wheels.
Part nos.front 944 612 111 00 and raer 944 612 112 00. if anyone can help.
Nick [:D]
Porsche OPC price is £76 + vat for each corner , don't think connectors are available seperatley because wires are moulded into them.
Used ones may be just as brittle and corroded and likely to fail so thinking about it further will probably go for new I think.
Nick [:D]
the plastic tube barrel connectors do unclip from their chassis holders/brackets but the wiring is moulded in and sockets at other end for main loom plugs to fit in.
Nick [:D]
Check out also the dash main harness. Several ABS system wires are located there. These wires goes from the fuse box to ABS pump harness.
