997 wheels
- Thread starter bennyboy
996 facelift:
Front - 8J, 50mm offset
Rear - 10J, 63mm offset
997 Carrera Sport:
Front - 8.5J, 55mm offset
Rear - 11.5J, 67mm offset
You can do the maths, or there is a handy calculator here: http://www.1010tires.com/wheeloffsetcalculator.asp
I was told 997 standard 235/35/19 tyres would be OK on the front, but actually the overall diameter is bigger than the 996 standard. This caused the inside of the tyre to foul the base of the suspension strut at high speed or on sharp cornering due to the extra downforce on the car. The rubbing/vibration this caused removed the fun of driving the car!
I fixed the problem in the end by fitting much bigger spacers than necessary on the front, but a 30 profile tyre would've been an easier answer if I'd known at the outset!
Cheers,
Neil.
