I took the opportunity to get more acquainted with the new model in and around the Millbrook facilities recently - although it was a relatively short session to understand such a vehicle these are my immediate impressions of note - I'm a 996TT owner and don't have previous experience driving a 997 so apologies if certain comments are old-hat from earlier 997 models.
Comparing the 996 with the 997:
- Generally the car felt more precise: the steering is enhanced via the variable ratio gearing (manual device rather than electronics); the seating position is better suited to a sports car I think being a little lower and even the standard seats provide for good control through the bends.
- On road the "comfort" suspension option takes away some of the hardness of the 996 suspension - as well as handling humps more smoothly, a welcome relief I believe on crappy UK roads I'd have thought.
- If using a Tiptronic the gear changes are smoother, i.e. generally less perceptible.
Acceleration
- In a word phenominal: power perceptibly more readily available across the rev range - compared with the 996 the turbo lag is now quite minimal, i.e. you notice the difference.
- The amount of grip is incredible - even with the instructor driving I was would have expected more electronic intervention being used in high speed cornering manoeuvres.
Braking
- Brakes were standard (not ceramic) and perhaps impressed more than acceleration: braking hard from ~155mph (something I don't normally do) there was next to no veering at the wheel and this was further exemplified by braking with no hands on the steering wheel from 85mph.
Sport Chrono
- I think this option is useful although perhaps largely suited to track day use. You get a little more play before the safety electronics kick in and the braking pre-fill is disabled (there are other configurations which are re-mapped such as damping generally as well as under braking but I can't quite remember them all...). The over-boost function provides extra torque for a limited 10s - accelerating hard you could feel the difference particularly in the Tip version where you have don't have to worry about gear changes.
Tip vs Manual
- I rarely drive manuals but was able to quickly get the hang of the box which was very precise. One possible drawback over the Tip is that under hard accelaration both 1st and 2nd gears don't last long before the rev limiter kicks in - that said it was incredibly enjoyable and reminds me how much fun a manual can be, i.e. I wouldn't rule it out.
- In combination with Sport mode the Tip. holds gears longer under acceleration.
- Gear ratios aside the launch mode option with the Tip. must provide an edge on manual acceleration times. (Sport mode ON: left foot hard on brakes, floor accelerator, revs stabilise at ~2,500, turbos pressures build, release brakes). Even the build up is exilarating - roaring engine sound like aircraft building up revs before accelerating down the runway. If the rumoured DSG ever makes production it will be one awesome combination.
Summary
- Awesome.
- Developments over 996 are more perceptible than I imagined. The improvements to the handling combined with the improved power curve at the lower end enhance the car significantly for every day road use. At the sports end the adapted 3.6 is notably enhanced with VTG married as ever with exceptional brakes and safety features.
- still like the 996.
Would be interested in reading of further experiences etc. so far of the 997 Turbo.
If anyone thinks I have misrepresented a feature etc. pls correct also as there was quite a lot of new information to take in.
Acceleration
Braking
Sport Chrono
Tip vs Manual
Summary
- Awesome.
