Is it my imagination or does the sport mode on the 997 Turbo make the exhaust note very slightly harder edged at idle or low speeds. I've noticed by toggling between sport on and off at idle does change the noise slightly and its even more noticeable when the car is cold. Is there a technical explanation as I thought there was no bypass valve trickery on the turbo.
By the way, mine now run in with 2000mls, doing 20 mpg, used 1 litre of oil and 3rd gear is still hit n miss (its a manual with short shifter). It has also a tiny oil leak started and all the front lights fog up inside when it is damp (including the LEDs) which is kind of disappointing. The bridgestone tyres are so-so in wet. Even with all that, I wouldn't have anything else as it is a stunning car.
