997 gen I satnav
- Thread starter 65505tb
If you're a Club member, you can access full details in the Members Only technical section.
Regards,
Clive.
Hi Tony and welcome,ORIGINAL: 65505tb
Hi, I'm a newbie so forgive me if I'm asking the obvious, can I upgrade my satnav, gen I 2008 car, to take full seven digit post codes, if so how do I go about it, thanks.
I have changed your "status" to PCGB member so you can access said Members only technical section! That said I don't think a Gen 1 car (PCM 2.1) will be upgradable. Only the late Gen 1 turbos had PCM 3 which may be upgradable. But, as Clive said, have a look at what is in your car.
garyw
Moderator
I'm not aware they have ever done the 7 digits for that version.
I never had a problem as I worked around usually by finding a venue rather than via a postcode.
