Hi all, my 2005 C2S has 'forgotten' it has heated seats and rain sensitive wipers (I had the battery disconnected for 24 hours to replace a window regulator). Is there a diagnostics device I could buy to reconfigure these so they work again? Also, would the same device allow me to make cruise control work if I retrofit the parts needed? Thanks Barry
997 - Diagnostics Tool?
- Thread starter barrygale
I think the Foxwell NT530 can re-enable options. I'll have a peek in the options list the next time I'm in the car or you pop onto the Gendan.co.uk website and mail them and ask. I think Gendan are the main importer of Foxwell.
Thank you. I had a chat with Gendan. They were very helpful but couldn't be 100% certain that a NT530 would do everything I wanted -- looks like a trip to my local specialist to get a PIWIS update soon!I think the Foxwell NT530 can re-enable options. I'll have a peek in the options list the next time I'm in the car or you pop onto the Gendan.co.uk website and mail them and ask. I think Gendan are the main importer of Foxwell.
NT530 is a good piece of kit - but you have landed squarely on "things it can't do"Hi all, my 2005 C2S has 'forgotten' it has heated seats and rain sensitive wipers (I had the battery disconnected for 24 hours to replace a window regulator). Is there a diagnostics device I could buy to reconfigure these so they work again? Also, would the same device allow me to make cruise control work if I retrofit the parts needed? Thanks Barry
Remembering lost options ( heated seats, headlight washers etc.) requires a function called "Handover Reset" - and thats a PIWIS only function as far as I have been able to tell. - It's not just a case of ticking the "has heated seats" option.
Cruise - needs coding in the 3 places in a 997 - the DME, the Steering column and the Instrument cluster - the 530 can do DME and Steering column - but not the cluster.
Some indy's will have a PIWIS and will run the process for "not much", similarly, some enthusiasts have the equipment and will "code for beer". Suggest reaching out to your local region and see if anyone local is equipped, or post on here your rough location and someone might be able to help.
