So I have had my other issues sorted but my specialist couldn't sort the roof. I have noticed something strange and wondered if any others on here could let me know if this is right as it may lead me to my problem solved.
My latch won't latch it just grabs and let's go and does this over and over. (When trying to put the soft top up)
I've had the roof calibrated and the piwis says all microswitches are ok. The rear control unit was swapped and still the same issue. I have recently changed the microswitch in the windscreen and sourced another convertible top ecu. Still the same.
I have noticed by accident that the soft top will try and come up with the hardtop on and latched, this to me doesn't seem right and could cause alot of damage (my key was in my pocket when I Bent over and it triggered for a second) is this normal you wouldn't think it was possible and should be some safety system here. Also should my windows drop a little when I unlatch the hardtop?? As they don't. This to me would indicate a microswitch problem in the screen part which I have changed.
If anyone could help here before I am forced to take it to a Porsche main dealer this would be fab. It has to be something simple, surely??
