I have just tried to start the engine of my 2009 997.2 C2 after a layup of about 4 weeks in a garage on the ground floor of my house. The garage is not damp.Neither the temperature nor the humidity in the garage should have been abnormal. Other than this, the car has behaved itself perfectly up to this point.
The battery has been on charge during this period with a CTEK MSX 5.0 charger so, for the moment I am assuming that the battery is OK.
When I turn the ignition key beyond the ignition ON position (to start the engine) there is the sound of a relay clicking about 2 times per sec, the whole dash display flashes on and off and the engine does not turn. On returning the key to the ignition ON position, the yellow engine warning light is ON, together with several other warning lights and the ABS failure and PSM failure warning lights appear one after the other. Also the electric windows do not operate when opening and closing the doors.
Any suggestions of things I could try before resorting to getting it towed away!!
Will
Will
