JulesInFrance
Hi All.
I have a failed aircon compressor and am about to start renewal of the necessary parts: new compressor, new condensers, new dryer, new expansion valve, etc, together with flushing of all lines. I have all the necessary parts and equipment (e.g. flushing stuff, vacuum pump, etc) but have a question regarding how to re-oil the system upon reconstruction.
I watched a very informative video from Repair Geek on you tube (https://youtu.be/N_msH6TX2W4) which says that you need to add the correct amount of oil in various parts of the system.
However, my new Denso compressor, which is pre-filled with exactly the right amount of oil) has instructions which say do not empty the compressor (and therefore I guess do not redistribute oil around the system), just start the air con after gassing on full with revs at idle for 5 mins.
Note that both sets of instructions include the very important manual turning of the compressor before starting up to prevent hydro lock.
So my question is, which advice do I follow: 1) Repair Geek who says put the oil in the different parts of the system or 2) Denso, who say do not do that, just run it on idle?
Many thanks in advance.
Jules
Jules
