996 Turbo S ownership
- Thread starter McBruce
I took my car for an inspection/gold service at Hartech when I got it (7h drive from me) but they do the most thorough inspection I know of. It gave me a great peace of mind to then enjoy the car freely.
unclewinks
Not a expensive fix but annoying
ashley
Enjoy it they're great cars
The main advice I would give you, if you haven't owned a turbo engined car before, is always ensure the car is fully warmed up before unleashing all the horses and give it a few minutes to cool down before switching off after a spirited run.
ORIGINAL: Spy
+1 VERY good advice!! Try to give it extra time after the water guage gets up to temp to allow the oil and components to be warmed through before giving it a thrashing.
Also the best way to warm up/cool down the car is not to leave it idling. It's much better to hold the gears slightly and let it do 3-4k rpm before changing so that it gets up to temperature faster than leaving it idling for 10mins, just don't be aggressive with the throttle/boost. When cooling the same thing applies, try to drive off boost for the last 5 mins of every journey rather than thrashing it and then leaving it idling in a carpark for 5 mins.
Your car will be most grateful for these habbits. They are more than happy to take anything you can throw at them the rest of the time but thrash one cold and it will soon damage something.
[quote
The cylinders are tolleranced so tight that when warming up it will send most regular compression testing kit off the scale!
I am not sure I quite agree with that,Turbo engines per se usually run looser tolerances because of the heat involved when on boost,so when cold they are not in optimum condition as the warm up the tolerances decrease.If you ran a turbo engine with the same tolerance of a NA engine the engine would seize.That was certainly my understanding of the engineering principles.That said modern turbo engines run higher compression ratios than years ago principally down to engine management and indeed closer tolerances than old though other factors like better metals and oils etc play a part.this is principally why turbos use more oil there is more oil passing the rings when they are cold.
My own advice consists of an oil change every 5000 miles there is no cheaper insurance for the engine although lots is written about which oil i use the porsche recommended one and from costco is cheap the oil is even more important in the turbo as it lubricates the bearing.
A post from pistonheads suggested the engine oil was fully to temperature when the oil pressure was stable this is usually just under 2 bar,and quite often takes a full 10-15 mins of driving to get there.to me this does make sense and i use this as my benchmark.As stated elsewhere i would wait until the engine is fully warmed up before giving it the beans
Otherwise usual turbo maintenance issues,however and this is just personal with the S as it has the brakes get the suspension sorted i saw Chris and got the x73,speak nicely to the boys at fearnsport( as they used to be ) the S was sort of set up for this thing you will never regret it it really makes sense and economy doesnt suffer ,and I also had a chat with Gert at Carneval for one of his cost efficient exhausts.
Then get out and drive it, I admit it isnt my daily driver when i use it as such ,and you can, it feels less special.This is all said having just done 1100 v enjoyable miles cross continent at high speed cruising fully loaded up with baby and wife the economy was 22.5 mpg.Enjoy.And judging by the reaction In Budapest you'd think you where driving a Zonda
I am sure Richard will correct me but Porsche i think quote as much as a 1/2 litre every thousand miles which to me sounds very excessive I noticed when i went on a hoon to scotland and did 1600 v fast miles i used between the full mark and the bottom mark. lots of short trips use more re comments about the increased clearances around the rings when cold ,if you are worried re the useage you could get a leakdown test which will give you a very good idea of the engine condition however it means the rear PU off out unless the problem is really critical i would leave however a good indy will help you make a balanced decision.there is no doubt if you drive it hard it uses more oil
ORIGINAL: richard hall
You know I always say how tight the tollerances are in the engine because they come out so high on compression tests but I've never thought the comment through before. Embarrassing. You are quite right! Post ammended.
McBruce that consumption seems pretty high to me. Mine moves 1 block on the digital guage about every 750-1000miles and that is with a LOT of hard driving. I would recommend getting that check sooner rather than later. It's unlikely to be anthing really serious but you may have an oil leak of one of your turbos might be allowing oil through the bearings.
How many miles has it done? Congratulations though, how are you enjoying it so far besides this little quibble?
Regards,
Ben
What do you guys recommend service wise? I booked it into a porsche specialist for inspection/service/fluid changes but should I go for dealer service and maintain a OPC service history?
