... are getting a bit low. Discs look fine. I recall previous advice to go for Textar pads, but they seem unavailable. I notice that other makes are listed as being with and without roller weights. (Do roller weights reduce vibration/squeal, etc?) What should I choose?
996 TT front brake pads
- Thread starter Gimme Shelter
Yes, the things that look like rollers are part of the anti-squeal shims. There's mixed views on re-using them - given the metalwork doesn't get worn, I don't see any reason not to re-use them with new pads, providing you can get them off the old ones! If you do re-use them, put a layer of CERA-TEC lubricant between pad and shim.
design911.com do a nice range of pads of different "strengths" including Textar:
http://www.design911.com/Porsche/996--911--1997-05/996-TURBO-2000-05/Brake-Pads-Standard/pt66_201_-cma81-cmo110-ct351/
They sell the wear sensors too, but again these only need replacing if they actually activated - and you can get them out of the old pads without damaging them.
ORIGINAL: T911UK
The roller weights are not anti squeal pads, two different things, both are there to try and stop squeal/vibration
You are quite right in Textar not doing weighted pads for the turbo, Pagid and ATE do weighted pads
Have you got any photos? I am now intrigued!
