I am posting here as I am led to believe that the later 996s (2002 onwards) share the number plate light fitting with the 997 (among other models).
Last Friday, a replacement for a broken number plate light fitting arrived in the post (ordered from Design 911) so I thought I would quickly fit it before the weekend in case I took the car out. The existing one was clearly broken as it kept dropping down from the bumper.
Unfortunately, I hit a snag trying to disconnect the wiring and this coincided with the Club Forum being down for the platform upgrade, so I resorted to posting on the 911uk forum instead (post http://911uk.com/viewtopic.php?p=1023224#1023224).
I have now managed to disconnect the wiring, but when I try to put the new fitting up into the bumper, there just doesn't seem to be enough space to manoeuvre the fitting far enough to the right to fit the fixed lugs on the left inside the bumper to then push the right side up so the spring clip clicks into place. It is the spring clip that is getting in the way, perhaps that is why it was broken on the original fitting in the first place?
The car is a 2003 MY 996 coupé, so the number plate light fittings are the same as the 997 apparently, not like the ones on the early 996s.
Has anyone else had experience of fitting this type of number plate light fitting and if so, are there any tips for how to manoeuvre it into place? I wondered if the screws holding the lens and bulb were fouling anything, so I removed these and tried that approach but it made no difference.
I am attaching a picture showing the broken fitting out of the bumper for reference. The replacement fitting came in a box with a Porsche part label which shows the part number as 99763162002.
Help!
Help!
