996 headlights
- Thread starter Guest
I don't know what you are complaining about anyway. Your headlights will be like a lighthouse compared to my 3.2 Carrera's candles!
Diver944
It's just my personal opinion but I think these modern lights are simply too bright and dangerous [
This was easy for me as I retail this conversion.
The kit contains:
2 ballasts
2 igniters
2 hi / lo beam controllers (H4 kits only)
2 HID Xenon capsules
Wiring loom and connectors
Upgrade fuse
Mounting plates, cable ties
Adhesive pads etc.
Waterproofing grommets
Installation instructions
It's a fairly easy DIY job and the results are excellent.
Main beam is excellent but dipped headlamps provide a limited spread with a very sharp cut off - a problem on un-lit roads where there is intermittent traffic coming the other way.
Do I need to get my eyes tested or have I simply been spoiled by the excellent headlamps on my previous car, a Mercedes S-Class ?
Graham.
Are the beams coming back up again after they dip down to calibrate when they are switched on? You should be able to see the beam lower and rise back up to the standard "dip" position.
