Dear all,
I was just looking for some common sense advice.
My well maintained 996 C4S has done 85K miles and is currently in with the OPC with an oil leak issue.
It drives beautifully, but whilst the gearbox was out I thought I'd have the clutch replaced - OPC says it looks worn; but the flywheel looks fine and they have recommended not to change it.
But - would you replace the flywheel along with the clutch? (I am definitely changing the clutch)
I am in 2 minds. The enthusiast in me says no brainer - it is simply the parts cost as the area is exposed.
On the other hand, it is very expensive and if it doesn't need doing then that money could go on so many other things!
Thanks in advance, I am really in 2 minds.
