Started my car this morning to come to work, and did not get the usual higher revs on first start and notished sounded a bit bunmpy
As i was driving the engine mamagment light came on with a message, drive to workshop, called local porshe man, he asked how was it driving i mentioned that the drive was fine but every now and then in morning rush hour traffic the engine management yellow light would flash about 20 times, any way, got to the office and switched the car off and then restarted the car, no engine mamagement light or anything apart from a slight tappet noise coming from the engine, called the aa to stay safe and when he attended he put it on computer and came with the following fault codes
P0300 Multiple misfire
p0302
po303 Misfire
po304
po305
and mentioed engine running ok and no E.M.Light on, adviosed going to specialist and mentioned that he would not clear the codes as the specialist may not find them other wise
i need assistance as the car had a re con engine put in in late december, at a cost of £4500.00 he lost the vat for me as a favor, as he does all my work on the car, called him and he advised driving the car and to see if the fault comes on, am worried as all i am doing at the moment is giving money away for poor advise, as my last engine started with misfire in cylinder 43 and then on the day at the garage he told me the engine was spewing wayer and the engine had gone, so you may see my dilema
any suggestions on the codes and the tappet noise, car was fully serviced when engine put in and the tappet noise has only occured his morning with the engnine management light on
thanks again for taking time out to possibly assist in a feesable soloution
p0302
po303 Misfire
po304
po305
