996 Brake Conversion Help
- Thread starter p.bestie
cheers robin.
996_STEVO
The Alcons will fit but you will need an adaptor for the caliper, plus a new set of wheels if using stock wheels, you might get away with a large spacer as the Alcon discs are way bigger and will not clear the inner wheel.
Trust me, I have been down this route the cheaper and more cost effective way if you are doing some track work but mostly road is the 6 pot GT3 Calliper and the 997 Turbo Steel Disc. You will need some nice Pagids also
