If I manually release and check the Roof as per the user manual Is it just a matter of reversing the instructions to get it working again
or will it need resetting
Previous message
r
AS you know I recently had a problem getting the roof to work after removing the Hard Top
Fixed that by disconnecting the battery - Could not use my reset box
However initially it would not fully close. Kept opening and shutting it and it was OK
Seemnd OK for a couple of days but again it is not always closing fully.
Feel that some thing is catching.
How do I release the roof so I can test it manually and if I do so can I reset it to work automatically
On a BMW you pull a lever that releases the gears then reset the gears and push the roof button while turning on the ignition
On a Merc you release the oil pressure (remembering to reset the pressure when you want it to work!!!)
