A few points that might help. First off before putting the old suspension in the nice shiny KW box (that's where my old set is !) it's worth making sure all the basics are covered. Are the tyres good ? i.e. they're less than a year old and if not the sticky R tyres do they have reasonable life left in them ? Quite a bit of difference happens in tyres and pressures alone. Old tyres will screw the handling. The cars are very adjustable and the geo for one track might be less effective on another. Once satisfied that it's not any of that there are a few things to note on suspension changes.
There is quite a choice. You might want to base your choice on what you want most , i.e. good track manners or good road or a compramise. The cup cars use single tube dampers with linear springs (the standard RS are twin tube design at the front) if you use your car mainly on track and those tracks are billiard smooth then that is the route to go. Be mindfull that you will need new top mounts(monoball) as these are unique to the RS Twin tube damper. These will add to your cost.The 993 fronts are well worth a look if your not wanting to refresh the whole suspension. Next up are the dual spring set up's that are made by various companies , these in general will improve the on road experience for reasons already explained in other posts. To the best of my knowledge KW are the only company (though this might have changed by now) to offer a suspension kit that is designed for the RS's Monoball top mounts . The other manufacturers expect you to buy their top mount, which is ok if yours are worn out.
I'm no chassis expert so can only describe my setup as i find it. The dual spring set up definately improves the on road experience, the car feels like it soaks up the bumps better whilst still retaining the stiffness and lack of roll of the original set up. it still retains the RS character if you like. It's also better under braking . The same applies on track . I don't notice that much difference on smooth tracks but on bumpy surfaces and more undulating tracks it's better than the standard set up. The difference is notable braking at paddock hill which has quite a bumpy section in the braking area.
Hope this helps.
Hope this helps.
