993 tyre choice
- Thread starter Guest
ORIGINAL: MoC2S
He's talking front tyres, Lawrence ... []
cheers, Maurice []
Oops! Blame a bad hangover!
ORIGINAL: MoC2S
Hence an S02 in 225/40/18 has a theretical r.d. of 637.2 mm, while the real (manufacturer's) r.d. is 642.62 mm ....
Not trying to be picky here Maurice, but the ABS can't be that sensitive, can it? - after all, the tyre is going to wear more than 10mm from the diameter during its life.
ORIGINAL: matzxr
[8|] Happy Christmas evryone .
Has anyone fitted 205 45 17 rather than the recommended 50 profile to the front of their 993's ?
That 50 profile looks SO dated !
Mat
the profile is a function of the tyre width
but unless also change the rears by adjusting their profile to mirror the front change then you will end up with a small wheel on the front verses the back then what was intended..... and there will be ride differences by doing this... but as a basic rule differences to 2-3% are ok.... even though certain tyre places quote 5% ! which I think is wrong exp' on a performance car !
if you after a look then you should consider going up to 18's ?
