993 to LED`s
davepaul993
hi im thinking of changing to led`s
has anyone done so & can you recommend
where to get them from please
dave
Dave
I did mine last year. headlights and all exterior
I also did the dash and centre console
I did a post on the forum and will have a look for it later. I have Pictures too
All plug and play and can be put back to standard too.
Headlights take all of 5 mins each to do too
All the exterior was from Bergvill
http://www.bergvillfx.com/index.php/
Graham
just thinking of doing the brake indicators reverse & fog etc
not sure about dash or console at the moment
ive already had headlights done
just seeing whats best out there now.
got them n all fitted they do make a difference i like it
just got centre console to do now.
thanks for all your help.
Also very easy to install. Hardest was the side repeaters with the Rubber sleeve!
Centre Console just take a bit longer to de-solder, cut the track and solder the resisiters and LED's in.
Well worth it
I'm still trying to find a mod for the pull out knobs (Fogs & Rear windows) cause if you use leds they are on full brightness all the time like the fogs etc are on so left with old bulbs for now!
Graham
Hi
Looking at the Bergvill site it seems as if the headlights are HID and not LED, is this correct?
Jim
Hi Jim
The Headlights are HID all the other lights are LED
The HID make a much better drive at night, can see the road! [:)]
Graham
