993 RS dampers query
- Thread starter ubertub
You will need, for example, the RS front spring tops as well.
Also, the RS dampers are valved to work with springs that have a spring rate much firmer than the H&R lowering springs. The combo will result in a crappy ride.,
Bilstein makes the RS dampers, so if you want Bilstein shocks, you better go with the Heavy Duty ones as they will match the H&R lowering springs far better.
