993 heated seats?
- Thread starter Mike M
scaramanga
Thanks!
jboult
The pads work well (seat base and back), although with only two heating selections they're not as variable as the old 944 seats I had, and they don't heat up quite as quickly. Still great on a cold morning though!
Cheers/John
Mike M
Cheers, Mike
jboult
I think it's usually just a contact problem when the switches fail/go intermittent. I had a couple of bad ones on my old 944 that I took out and cleaned, and they worked fine afterward. Can be very fiddly to do, though, and the irritating thing about the switches in the 944 is that they are soldered in at the switch end, with the plug being at the far end of the lead where it goes into the loom, making removal and refit much harder that it should be (basically seat out). I can't remember if it's the same for the 993, but I would guess so as the units seem the same.
Cheers/John
Mike M
Again thanks for your input John.
jboult
Sounds like it's the same as the 944 - cable ties holding the switch cable onto the seat prevent you pulling the switch out. At least taking the seat out is easy! Good luck, and take care with the switch. You shouldn't have to open it up, but if you do I seem to remember there are some fiddly springs inside that can pop out.
Cheers/John
Mike M
Got my switch fixed today, seat came out no problem at all, however I found it easier to de-solder the switch rather than un plug and disconnect all the cables at multiple termination points. Stripped the switch and gave it a good clean, your right though re-assembly was a pain. Soldered the connections back up and worked perfectly! Just as well saying a replacement switch was a nearly £100!!!
Curious to Why there's a two pin socket spare under the seat, will post a photo when I get the chance - looking for ideas!
Mike
Seatbelt sensor perhaps?
