My 993 2s has been parked - in a garage - since last Oct. Garage is not heated so can be somewhat damp during the winter. When I parked her up last year all was fine and certainly no warning lights.
With the first of the decent weather last weekend I initiated my first drive of the year. On start-up I have a whole raft of warning lights up plus the Speedo has stopped working. I did drive the car for a short while just in case of a damp/short circuit issue that I hoped might clear. No lights cleared. The car drove fine and apart from all those lights I noticed no difference in response. I'll book into a local independent to investigate but ahead of this does anyone have an ideas, or similar experiences, that my indicate the root cause. The car has been maintained regardless throughout the last 5 years despite v low annual mileage of 1-2k pa. All fuses are good as far as I can tell. I have not attempted to pull and re-seat relays.
For the record I have the following flagging up:
Speedo "" no reading; Low fuel indicator(Yellow); Low washer fluid(Yellow); Central warning light(red); Brad pad wear (red) ( pads all good); Handbrake (red), Oil pressure (red) "" I run 5 bar at 3k revs on gauge; Brake pressure (yellow) "" brakes a good; rear spoiler warning(yellow); engine fan belt(red)
I have 2 thoughts re cause:
A number of relays have corroded/poor contacts from an extended period in damp garage over the winter
Rodents have potentially attacked some aspect of the loom and I now have some random short circuits?
Any other thoughts or suggestions I could try/eliminate before I hand my wallet over to the professionals?
