paulwalters
My 1996 993 C2 has a problem with the cabriolet hood. While away on a drive recently I had the top down, however on arrival at my destination the top would not close using the toggle switch in the cabin. The front of the hood would not lock on the top of windscreen frame leaving a 50mm gap. At this point I retracted the hood back to its fully open position and tried the switch again but the hood did not move at all. As I could not leave my car with the hood fully open, I loosened the 19mm bolt each side of the rear seats which enabled me to close the hood manually, although the front locking still did not work using the toggle switch. Eventually I managed to lock the hood to get me back home and have since had the fault investigated by an independent Porsche specialist. The problem appears to be the hood transmission gearbox x 2 due to overriding of the micro switches which is going to be a very expensive fix. I have seen on other forums that many 993 Cabriolet owners open and close the hood in the manual mode and just use the toggle switch for the front locking. Have any other members had similar problems ? Any suggestions on this matter would be much appreciated.
