Have been away for a few weeks, and before going, I was unsure if I should have connected the CTEK, but didn’t.
After retuning home I went to start the car , and it ‘just about’ turned over and fired, but the dash lit up like a disco with many error messages, chassis failure, locking failure, coolant low, etc.
Eventually, I thought I should put the CTEK on overnight and try next day.
It then fired up easily, but showed an error message, ‘convertible roof faulty’, ok to drive but see dealer. I tried the roof switch but nothing. I also tried to open the small rear engine access flap but that didn’t work either.
I thought it may require a short run, so it could try and reset itself after the many errors I saw the previous day. I also switched off and locked the car, believing that may also help the reset. But when I did a short peep emitted and the light on the inside window triangle glowed for approx 10 seconds then went out. It usually continually flashes when locked.
So I went a short drive, going above 60 so the rear spoiler would rise, and came back to check. No change, convertible roof still errors and locking not right.
I then noticed that the rear spoiler didn’t seem to fit as flush as I remember, so did the process as per a suggestion on this forum, get someone to sit inside and press spoiler switch to raise and lower, and when it was lowering putting gentle pressure to ensure it seated, but that still didn’t help.
I have contacted my OPC but all they can offer is to have it in first week in January.
With the temperatures as they are at the moment, I am obviously not bothered about a functioning soft top, but would like to try to get the locking sorted and be able to use the rear lubes access flap if needed.
Does anyone have any ideas what I may be able to check or reset to try and correct the fault?
I wonder if the rear spoiler isn’t seating correctly, perhaps the sensor is not allowing the engine flap and convertible roof to work as it thinks the spoiler is in the way.
Thanks anyway
David
Thanks anyway
David
