Hi. any Ideas re how to reset the windows To raise when closing the convertible roof? The roof opens and shuts fine but the windows aren’t auto closing. I can’t close the rear quarters at all! Any ideas? Thanks
992 cab windows not closing when raising the roof
- Thread starter Paulfranks
Hi, Sorry to hear of your problems. How old is your car? Are you aware of the rear Windows have ever auto raised when closing the roof. I am sure mine did when I first had the car (2019), but noticed after having a big software update to cure a SOS problem, they never seemed to auto close. So I have to press the ‘rear window’ switch then manual close using the front window toggles.
Perhaps its something I need to mention to the OPC when its in next month.
Regards David
Regards David
Hi. It’s about 6 months old. i wondered if there was an easy reset I could do without trip to Porsche again…thx for response David.
Try this, this is the standard window reset method, perhaps it works in combination with the Cab roof as well:
https://www.porscheclubgb.com/forum/tm.aspx?m=1091203
Paulfranks said:Hi. any Ideas re how to reset the windows To raise when closing the convertible roof? The roof opens and shuts fine but the windows aren’t auto closing. I can’t close the rear quarters at all! Any ideas? Thanks
I had a similar issue with my 992 Cabrio. Hood closed fine but front windows closed out of sync - ie left then right and one of the rear quarters did partially close then open again; I then closed it manually. I think the issue with the rear quarter was that it sensed an obstruction and OPC did an adjustment and then recalibration sorted the sequencing of front windows.
I am no expert on 992 hoods but I did spend a lot of time addressing hood related issues on my 997 and if that's anything to go by, you need a visit to the OPC to get them to run a diagnostic/recalibration on the hood and possibly some adjustment. It's unlikely any sensors have gone bad at this age but its always a remote possibility.
