992 1 4S Alternator Replacement
AJRUK
Hi,
I have been told that the alternator on my 992 1 4s is not putting out sufficient voltage and I may need it replaced as a battery tester is reading only 12.2v. Does anyone know if this is correct? Any idea how much to replace?
Thanks!
Usually should be around 14v when engine is running.
Replacement alternators are usually exchange units where they refurbish used units and swop with your existing alternator. You can also get your existing alternator refurbished and done this many times with varying cars over the years.
Suggest look for a local alternator repairer, where they will remove, fix and refit your existing alternator.
Recently did a relatives Boxster, where I removed the alternator and took it to local repairer who refurbed it whilst I waited. Cost £150 with warranty and came back looking like new.
