Graham,
It could be that the AOS is just on the way out which could be giving rise to a rough idle. As you say, a totally failed AOS gives a persistent cloud of smoke.
PCT are a reputable Porsche outfit and should be able to diagnose the fault(s) quickly and rectify the problem.
The Gen2 engines appear to be more robust - no IMS shaft to worry about and the Alusil process is used for the aluminium cylinder blocks whereas the Gen1 engines used a casting technique called Lokasil. Whether or not the Alusil process is superior to that of the Lockasil method is open to question, but there don't appear to be many reported cases of bore scoring on the Gen2 engines which have been running since about 2008.
I'm sure that it's something straightforward and quickly rectified. Keep us posted.
Jeff
Jeff
