Hi all,
I've had our 987 Gen 2 (about 27k miles, 2010 model) for about a month now but had a initial concern about the coolant level dropping. Over a couple of weeks (few hundred miles) it went from Max to Min twice and so a small top up was needed each time. I've always let the car sit on level ground and let it cool completely before checking. I bought the car from a local dealer who provided a years warranty. The car went back to them last week which I collected it last Friday, I drove it home after a 20 miles run and put it in the garage. When I checked the coolant the following morning, it was clearly still pressurized and it spewed about half a cup of coolant from the cap (which disappeared through the drain hole, over the engine and onto the floor). The level was still over Max. I called the dealer and took the car back over which is where it is now having further checks. The dealer said they have been unable to find any leaks and that it's not been easy for them to set a proper coolant level. They also say they don't have equipment to do a proper pressure test. I'm concerned about head gasket failure but they say this is very unlikely. I've asked them to check the coolant for oil contaminants which they say they will do today (a simple test I believe).
My query is I'd like to understand is why was it so pressurized after approx. 16 hours - could it be that the coolant had been overfilled by the dealer when I picked it up? Are there any other checks the dealer should do to eliminate my concerns? All thoughts very much appreciated.
Dave
Dave
