berty987
I´ve been watching the other forums regarding upgrades to the boxster and cayman engines. The fitting of a Gt3 82mm throttle body in place of the standard 76mm item fitted to the cayman 2.7/3.4 seems to have good results. I did some research and found that the 76mm cayman TB is offered by FVD as an upgrade for the 3.2 boxster. Though the inlet manifold of the 3.2 boxster is smaller than the cayman 2.7/3.4 (and boxster from 2007 onwards) the valves in the head of the S model boxster 987 and 986 are the same size as the 3.4 carrera 996. This suggests to me that the heads can take more airflow , particularly with a different cam.
A little more digging turned up some info on the 996 X51 powerkit for the 3.4. A higher cam lift , gas flowed inlet and exhaust tract and pistons to accommodate the increased valve lift , seem to be the main differences. Does anyone know if the X51 996 head would fit a boxster , since the bore is the same ? Has anyone tried this on a boxster ?
