HELP! Was a passenger in my wife's car earlier, went to put the window up & the whole switch unit came out loose.
Tried to push it back in, but suspected I have broken a plastic clip, the outer metal ones were visibly there.
I was pulling it up to assess further & then it 'came apart', so the switch, pivot, rubber section etc are all in pieces....but I can see the metal clip holders on the inner side that broke. This was only minor force, so can assume it was on its last legs.
Obviously easy to buy a replacement switch set up, but the cable seems extremely short to get to fitting the new now - wondering if this needs to be a door card off method to change it out?
Seem to be unsuccessful with the search feature, so if anyone here has done similar I'd love to hear from you.
Matt
Edit...now removed the surround, so can see it is not a card off job, just need to locate the original part - eBay seems full of the parts, but cannot believe an OEM Porsche part is going to be £20!
Matt
