981 Seat belt lower anchor point
Gazoak
I've owned my Cayman from new and noticed sometime ago that the seatbelt on the drivers side is twisted. It isn't the buckle and it isn't where the belt retracts in to the inertia reel. Unfortunately, the car is over two years out of warranty so knowing how the OPC's operate, they will probably want to charge me to sort this out. I was proposing to sort this out myself by removing the lower torx bolt but I don't have the correct bit size. Can anyone give me the correct size so I can buy the bit to do the job. Thanks in advance.
3 N 989 261 02 Fastening screw 2 7/16-20UNF
5 999 510 048 01 Pan-head screw 2 7/16-20UNF
13 999 218 101 02 Hexagon-head bolt 2 7/16-20UNF
Gary,
Just a thought but if you pop along to your local Helfrauds (or tool supplier) they may let you try different torx bits to get the correct size.
Jeff
Thanks for the replies and the diagram. It turns out that the belt was twisted behind the plastic cover so all now appears OK.
Regards,
Gary
