Widely reported elsewhere (eg 991 Forum) but can't see here. Cause seems so unlikely thought worth reporting.
Had "PSM Failure" and "Stop/Start Inoperative" warnings after driving for an hour or so at steady speed on motorway. Message says you can carry on driving carefully. Brakes seemed to be dragging slightly when slowing to stop. Messages disappeared overnight (I was on hols), but reappeared again after another couple of hours.
Quickly diagnosed and sorted by Porsche Centre Wilmslow (first time I have used them). The cause seems unlikely, but is plastic bushes at the ends of the brake pedal pivot pin which swell slightly when warmed by the heater, causing the pedal to not release properly. Can also lead to brakes dragging and overheating.
Fix is replace the pivot pin and both bushes. Took them about an hour and a quarter, including safety check which spotted a tiny screw in a rear tyre (about 2mm dia!). Good service from them.
