Cadenceminge
(New member)
So I took my 981 to an official Porsche dealer to fix the common brake bushing/PSM problem... while it was there they said the condenser and dessicator (dryer?) needed replacing because of what looked like a leak.
Fair enough despite the £840 price tag (or rather... there's not a lot I could do to test their recommendation). They drained and refilled the refrigerant as part of the job.
But when they dropped it off and I switched on the ignition the heater blower was stuck on maximum, and stayed on despite taking the key out of the ignition. Literally the first time I switched it on after the service. Eventually it ran the battery flat. They are claiming there is no possible way that the work they did to replace the condenser, dessicator and refrigerant could have led to the fault, and they want to charge another c.£900 to replace whatever has blown on the resistor board, plus a new battery
Q1: Is it mechanically possible that the new parts and refrigerant somehow overloaded the system when it was first switched on and run for a few minutes, that could lead to such a fault?? Not trying to be an arse, but just seems ridiculously coincidental
Q2: If I find out from them exactly what part needs replaceable, is it DIY-able, or eBay and local garage-able?
Q3. Really stupid question: can I easily fit a good quality battery without them doing it at Porsche prices?
Thanks in advance
Thanks in advance
