981 GT4 detent spring.
- Thread starter tracknut
Twinfan said:You may need to look for a used part, Porsche gearboxes are non-servicable I believe. I know someone who recently had to have an entire PDK gearbox replaced (under warranty, fortunately!) due to a failed pressure sensor within it.
Probably because Porsche have a failure/replacement warranty from the Tier 1 supplier who will recycle/repair, which is fine (subject to availability) for warranted cars but not so good down the road. I guess the level of failures is low because there is no secondary repair market in Europe, AFAIK.
AndrewCS
Do you have a part number, I am not seeing that descriptor in the diagrams. The part may be common to other models although probably only via Porsche supply for new ...
Cayman GT4 (2016) TRANSMISSION CONTROL Diagram (701-000) (eurospares.co.uk)
Who supplies the gearbox, if ZF then Transmission manufacturer | Mackie Automatic & Manual Transmissions | Glasgow (mackie-transmission.com) may be able to help ...
Oddly enough John, the PET for the 986 Boxster does show parts for that car’s transmission, so it’s possible that there could be a common part given that the mid-engine cars have always used a Getrag-supplied unit. If you’re looking for a reliable transmission rebuilder I would think that one of the well-established Porsche Independents should be able to tackle the job, although I’m not aware of any specialists.
Jeff
Yes these are my thoughts also, but there’s no part number on the actual unit, but they have got a local engineering company on board who says they can make something that would do the job, so
I was just referencing the 986 Boxster PET obtainable here [from page 125 for the transmission] if that’s of any use:
https://www.porsche.com/uk/accessoriesandservice/classic/genuineparts/originalpartscatalogue/
Jeff
I will update when I know more.
Thanks to you all for your input.
Regards John.
