Hi,
i just wondered if anyone can offer some advice regarding my 964.
Its had a starting issue for a while but I've always managed to get it going. It basically used to just click on the turn of the key with no attempt to crank. A few tries later and it would spin over. I changed the DME relay which seemed to cure it for a while until one morning it wouldn't go at all. Eventually it did with a starter pack on the battery and I drove it down to 9excellence who were due to do an oil change. Subsequently they couldn't start it and changed the starter motor and battery but the problem still exists although now it doesn't even click like it used to. It's just dead when you turn the key. To compound the issue its now stuck in limp home mode, the new battery doesn't seem to be charging and it got very hot driving home (transmission stuck in 3rd maybe cause it to get hot?). Now before it went to the garage the only issue was starting so I'm wondering if any wiring has been disturbed by them changing the starter as the gear change was fine before it went in. The oil pressure and temperature gauges were also jumping around and that has never happened before too. Anyone have any ideas ?
Darren
Darren
