964 rear calipers
RSGulp
Who designed the 964 rear caliper and its mounting on the suspension arm? The position of the lower bolt is an ergonomic joke. Surely it couldn't be a German, did any Italians work at the factory in the early 90s? [:D]
You didnt read, my note after I did this then warning of this? They arent that bad if you have the right tools, also, I"m hoping you swapped the bolts, as the bolts are likely to be chewed after extraction, so always best to replace. Then put back in with threadlock on the middle of the thread, and molyslip just under the head.
