964 Front Wings - Do they fit?
- Thread starter Anil
The major difference is the fuel filler neck system. On the 964 and G50 cars they are the same in that the fuel neck 'sits' in an oblong plastic carrier that can be unbolted from the wing (four easy bolts). The filler flap is screwed to this also. A doddle to remove. The filler neck is different on the 964 though and cannot be used for an earlier car.
On earlier cars a large rubber seal secures the filler neck to the body at one end and the wing at the other. It is a pig to refit. If you want to upgrade from this earlier setup you will also need a plastic carrier, G50 type filler neck and fuel flap to make it all fit properly. I think the later type is much better - the wing can be replaced in half the time it takes to swap the earlier ones around.
Hope this helps.
